Wifi, splitting
Toad20#
Repeat Guest
Message 28 of 28
I recently updated my talktalk internet and it seems unknowingly my router has been 'switched' to run at 5Ghz setting. I have BG smart plugs setup around the house and they all started failing. It seems they only run on 2.4Ghz. i have checked some other smart plugs (Tapo) and their instructions tell you they only run at 2.4Ghz too. At the moment i have gone back to old mechanical plugin timers! Can anyone tell me how to set my router up to 'split' the channels or do i need a new router from talktalk!? Help!!?
27 REPLIES 27
Toad20#
Repeat Guest
Message 21 of 28
Chris, how on earth do you give bands different names in a ssid? I'm 63, i can reboot a router and switch it off and on!
Message 22 of 28
HI Toad20,
If you want to try splitting the 2.4GHz and 5GHz bands you just have to give them a different SSIDs in the router settings
Toad20#
Repeat Guest
Message 23 of 28
I have reset the router a couple of times...rebooted the router a few times and its still not letting me setup my smart plugs!!! 😕 My router is a sagem, is this model prone to this sort of thing?
Message 24 of 28
How are you getting on?
Message 25 of 28
Hi @Toad20#
I assume the situation is that these devices are not compatible with the 5GHz band. The router will support both the 2.4GHz & 5GHz bands, not just the 5GHz one. I also assume that they need to connect via an app of some sort & here probably lies the problem. There are some of these apps (I have no idea if this applies to your app) that have been badly written from an IP networking perspective, which causes your problem.
Please can you tell me the make/model of the router that you have & I will try to help you get these devices connected.
Toad20#
Repeat Guest
Message 26 of 28
I have now reset the t router...and switched it off and reset it, and the BG smart plugs are still saying i'm connected to a 5Ghz  network and that i should go into the setting and set it to 2.4Ghz!
Message 27 of 28
Hi Toad20#
Please can you factory reset the router using the pin hole reset for ten seconds and then try and connect that device again?
