on 06-10-2022 11:24 AM
since yesterday I can't connect to my account the message I am getting is the requested URL was rejected please consult administrator your support ID is 7997971830122938190. any help please.
lyn.
on 12-10-2022 01:34 PM
hi
showing right password now but still getting the same message.
on 12-10-2022 01:09 PM
Hi lyntramp
If the password box has a saved password then that's because your browser has saved the old password and you haven't yet saved the new one.
Simply select in the password box after the password and delete the old password using the backspace on the keyboard, then when the password box is cleared, enter the new password and take it from there.
If you experience problems with the login then close the browser and start over by selecting this link to login: https://www.talktalk.co.uk/my/packageandservices remembering to enter the new password if you haven't yet saved that as the login.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
on 12-10-2022 12:49 PM
I have now changed my password which has been confirmed by email ,when I put it in to the log in section to acsess my account it keeps showing the old password
on 11-10-2022 01:45 PM
hi
could you please move this to the billing section as most of these problems seem to be on there, still having the same problem
on 08-10-2022 12:50 AM
hi
have tried different browser the message I am getting is "sorry due to technical issues we cannot log you in right now .please try again later. having looked on google this seems to be a common problem going back to 2021.
on 07-10-2022 02:20 PM
Hi lyntramp
Try using a different browser, and ensure you are using the correct link to My Account
