faulty router
anoyed
Whizz Kid
Message 5 of 5
hi is their any chance of a replacement router ive been running on sagecom fast 5634 for about 4+years now the wifi has been getting slower tried totaly wiping it and starting from scratch but didn't make any difference so i put old DSL 3782 on and speeds back up to normal but this one only has 1 band so a new one is needed thanks in advance
dave
4 REPLIES 4
Message 1 of 5
How has the connection been since the WIFI optimisation was switched off?
Message 2 of 5
I have switched the WIFI optimisation off, could you try a different wireless channel now to see how the connection compares?
Change your wireless channel
If you are still experiencing the same issue then please let me know and I will send a replacement router.
anoyed
Whizz Kid
Message 3 of 5
tried automatic optimisation made no difference need to try new router
dave
Skynet_TX
Message 4 of 5
Hi @anoyed,
Have you tried changing the channels that the Sagemcom broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested. Would just be interesting to see if this got the speeds back to something good.
Be aware that the Sagemcom router has a feature called 'Wi-Fi Optimisation', this means it can change the Wi-Fi channel itself, overriding what you have set it to, it can randomly do this after minutes, hours or days !. So if you do find a channel that works well, but then things go bad again, check to see if the router has changed channel to something different to what you set it to. If you do experience this problem then just post back here to ask the Support Team to disable the 'Wi-Fi Optimisation' on your router, once that is done it will stay on whatever channel you set it to.
But if changing channels is not making any difference, then your original request of a replacement router might be the best way to go, the support team here would be able to to help with that.
Anonymous User
