pptp vpn is not working
Message 9 of 9
good morning,
i have a problem getting into my work computer i believe its talk talk that are blocking the pptp vpn, please can i log this an an urgent matter
CHRISTINE WILKINSON
8 REPLIES 8
Message 1 of 9
Hi Christine
I'm so glad to hear this 🙂
I've also sent you a Private Message with a short survey for our Community.
Message 2 of 9
HI Debbie,
Perfect im onto my work pc now from home.
Thankyou so so much for your fast replys and resolving this issue
CHRISTINE WILKINSON
Message 3 of 9
Hi Christine
All updated, please can you retest and let us know how the connection compares.
Message 4 of 9
Hi Christine
Thank you. Started the update now and I will post back as soon as it's completed.
Message 5 of 9
Hi Debbie,
Yes this can be done as soon as possible please
CHRISTINE WILKINSON
Message 6 of 9
Hi Christine
Thank you 🙂
I will need to make a change to the router firmware, will it be ok if I do this update now? (this morning)
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Thanks again,
Message 7 of 9
hi Debbie,
i have done this
Thankyou
CHRISTINE WILKINSON
Message 8 of 9
Hi Christine
Thanks for creating a new topic. Please can you add your TalkTalk landline number to your Community Profile, I can then check your firmware version.
Anonymous User
