slower speed than guaranteed
Jacal2
Message 4 of 4
My speed check showed I am getting less than half the speed I am guaranteed and that there is a fault on the line between my house and Talk Talk . But how do I know if it is being fixed or even investigated?
Jacal
3 REPLIES 3
Message 1 of 4
Speeds are very low. Fibre test is clear however line tests are showing an issue.  Check the home phone, do you have a clear dial tone or noise on the line ?
Jacal2
Message 2 of 4
Profile updated. Very slow speed problem still persists. When will it be fixed?
Jacal
Message 3 of 4
  • Name
  • Telephone number
  • Alternative contact number
