Extending wi fi range
ANSWERED
6 REPLIES 6
I have the latest router but have issues in getting a  wi-fi signal in the rooms that are further away from the router. I have a wi-fi extender but the signal still isnt great. I am trying to find out the best way of strengthening the connection. Which is best, a network extender or wi-fi extender? I wondered if a wi-fi extender kit connected by Ethernet cable was the same as a network connector... just £15 cheaper.
A
Solution
Wrongly configured they can easily make things worse. Slow speed, intermittent dropouts, breaks in the signal, or no signal on some or all devices, might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
To enable me to help you, please can you specify the make/model of TalkTalk router that you are using?
Thanks Keith, im using the latest TalkTalk router - Antenna Array . I just dont know whether to buy more wifi extenders or network connectors. Then can i use the same network connector thats wired to the router to pair all extenders (wifi and Ethernet connected). Alternatively is an ethernet cable on a wifi extender as good as a ethernet cable on a network connector
A
What is the make/model of router and Wi-Fi Extender are you using? The next step is to see how congested your airwaves are & often simple reconfiguration of router/extender can sort this. I can offer a lot of help if you want it.
Hi Andymud,
I can see that Keith has offered to help you with this so I'll leave you in his capable hands 🙂
Thanks - fed up with Talktalk to be honest and so difficult to get any proper support from them so swiched to BT last night 😄
A
I'm sorry to hear that you've decided to leave, had you not seen Keith's kind offer of help?
