on 06-12-2023 07:17 PM
Was having general issues with my wifi randomly dropping when both bands combined. I have now separated them and it it clear it is the 2.4Ghz band that has the issue. It has got gradually worse and I am now having to reboot the router multiple times per day. 5Ghz band appears to work well but not all devices (Nest, Ring for example) support 5Ghz.
Looking at other threads, it appears a new router is in order. Any advice?
on 07-12-2023 09:47 AM
Hi Steve
Thanks for confirming this.
on 07-12-2023 09:15 AM
Hi Debbie,
yes, I tried that but it didn’t fix the problem.
regards, Steve
on 07-12-2023 09:02 AM
Hi SteveyW123
Thanks for updating your Community Profile 🙂
Can I just check, have you also factory reset the router using the pin hole reset for ten seconds?
If you have already tried this then please let me know and I can send a replacement router.
Thanks again.
on 07-12-2023 08:47 AM
Thanks Debbie, details added
on 07-12-2023 07:18 AM
Hi SteveyW123
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
