3rd party router
Deanosafc24
Whizz Kid
Message 3 of 3
Is it better to use your own router rather than Talktalks WiFi Hubs?
DMHALL
nambuso-TT
Message 1 of 3
Hi there
@fr8ys thanks for the information and @Deanosafc24 if you are experiencing an issue please do let us know so that we can look into it for you. Thanks
Message 2 of 3
Not necessarily, and support from staff cannot be provided using 3rd party routers.
Many do though use their own for one reason or another.
There are so many routers available though so you need to research well.
Are you experiencing an issue?
If so then of you explain it here, this can be looked into and hopefully a solution found.
