5Ghz wifi drops out
on 31-05-2024 10:42 AM
Message 6 of 6
I am a recently new customer to Talk Talk and my 5Ghz wifi keeps dropping after a day or so and requires a router reboot.
The 2.4Ghz wifi is always on.
From the router dashboard the 5Ghz says it is on but doesn't appear on any devices as available.
I have seen similar posts on this subject and any help would be appreciated.
Thanks in Advance
Labels:
- Labels:
Connection
Router
Stability
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
5 REPLIES 5
on 31-05-2024 01:07 PM
Message 1 of 6
Hi @ianfirth99
No that is fine, it was only if it was up at around 140 or higher that would concern me.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2024 11:59 AM
Message 2 of 6
Hello again Keith
2.4Ghz is on channel 6
5Ghz is on channel 44
I'm happy to drop that down from 44, based on your comment, or change it to AUTO to see if that helps
I will take your advice on that
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2024 11:25 AM
Message 3 of 6
There is a bug in V174 that if you disable any wifi band, it does not start working again when re-enabled, even though the router's GUI shows it as enabled. The only workaround is to factory reset the router. I have raised this with TalkTalk and hopefully, it will be resolved in the next version. There is no exact date for this release though. However, it sounds like you have already discovered this.
What 5GHz channel does the router show that it is using, as sometimes after a factory reset it uses a high channel number that some devices will not support?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2024 11:12 AM
Message 4 of 6
Hi Keith
My Router is:
TalkTalk Wi-Fi Hub 2
version SG4K100174
I have a couple of NAS drives and a Phillips HUE lighting bridge which are wired connections and which have no issues.
The 2.4Ghz wifi is always up but the 5Ghz drops even though it shows as enabled in the router browser.
Disabling the 5Ghz and re-enabling at this point does nothing. Only a full router power cycle or reboot brings the 5Ghz back.
Thanks for the quick reply
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2024 10:51 AM
Message 5 of 6
I can help a lot with all WiFi issues. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
