Unreliable connection - Can't log-in to router and won't save changes
moleycoley
Message 10 of 10
My wired PC connection has been alternating between dead slow then accelerating up and down for about 2 weeks now. I try to log in to the router to check the settings and sometimes it lets me log in, other times i can't at all. Even when i do log in any changes aren't saved and sometimes it restarts and kicks me out. Any suggestions - or do i just need a new router?
9 REPLIES 9
Message 1 of 10
Message 2 of 10
thank you
Message 3 of 10
The router will be free, I'll order it now
Message 4 of 10
yes please. that would be helpful. will the router be free or do i have to pay for it?
Message 5 of 10
OK, I can send another router to test with, would you like me to arrange this
Message 6 of 10
i don't have a landline phone to test it.
Message 7 of 10
Hi moleycoley,
Line test is passing and router is in sync at 40Mbps. Are you experiencing any problems with your telephone service, is there any noise on the line?
Message 8 of 10
Added it now. Though I don't use the landline number
Message 9 of 10
Good morning,
  • TalkTalk Telephone number
