on 28-08-2025 12:31 PM
Have just signed up to new 2yr deal and received a new router, TTSCOMFAST5364-4.T8. But only c.6 months back an engineer replaced my old faulty router with a TTSCOMFAST5464-2.T4.
Everything is working OK, is there a material benefit in installing the "new" router model? Thanks
on 01-09-2025 08:03 AM
Hi @rlwoufc1 please confirm if you still need assistance.
on 29-08-2025 09:47 AM
Depending on which new router you were supplied with @rlwoufc1, it might well be a higher specification than the 5364.
on 28-08-2025 12:44 PM
Hi there @rlwoufc1, thank you for reaching out. Yes If everything is working well with your current router, you may not see a significant benefit in switching to the new model. However, if you want to ensure you have the latest technology and features, or if you experience any issues with your current setup, it might be worth installing the new router.
