Broadband down
blackicerose
Message 10 of 10
My Internet suddenly went down last Friday evening and we've had no Internet since. Testing the connection tells me that there is a fault with the line and that it's being investigated. The first open case is no longer showing so I'm assuming it was marked as solved, I have opened a second case but it hasn't been updated since this morning. I work from home so I rely on the Internet. Is there anything I can do to get it back on? I have reset and turned on/off the router several times, all I get is a flashing orange light.
Case number is REP-13037081
Thanks in advance.
9 REPLIES 9
Message 1 of 10
Message 2 of 10
Yes, everything working now. Thank you
Message 3 of 10
Hi blackicerose
Thanks for your reply. Just to confirm, is everything working ok now the cable has been secured?
Debbie 🙂
Message 4 of 10
Hi Debbie, thanks for your help. I just looked at the ONT realised the puppy and his ball had pulled out the power to the unit! Sorry for the hassle, I appreciate your help!
Message 5 of 10
Hi blackicerose
The line test is clear.
Have you tried connecting a device directly at the ONT? (just so we can see if its a router fault)
Message 6 of 10
Hi Debbie, it's FTTP263147
Message 7 of 10
Hi blackicerose
Please can you also add your TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Message 8 of 10
Thank you very much.
Divsec
Message 9 of 10
Hi @blackicerose you've done the best thing and contacted the team here, your post has been escalated and you should hear tomorrow.
