Broadband dropout & speed reduction
SoF00
Message 31 of 31
Hi - We have been having short (2 - 3 minute) broadband interruptions for a while now and the internet speed is also below the guaranteed level although still usable.  Connection test says there could be a line fault but line test says unable to identify a fault on the line.
30 REPLIES 30
Message 21 of 31
Of course .... now plugged into faceplate/test socket
Message 22 of 31
The test socket is the socket that the faceplate plugs into
Message 23 of 31
Looks like an FTTC
Message 24 of 31
Which type of socket is it?
Message 25 of 31
Two wired in telephone sockets.  Phone socket looks like it should have a test socket but having just removed the front cover it doesn't seem to have.
Message 26 of 31
Thanks. How many telephone sockets do you have? Is your router currently connected to your test socket? Your guide to main phone sockets - TalkTalk Help & Support
Message 27 of 31
We don't use the landline that much but it sounds fairly clear when we do with just the odd crackle
Message 28 of 31
OK thanks. Are you experiencing any problems with your telephone service? Any noise on the line?
SoF00
Message 29 of 31
Hi Chris, yes the router light goes to flashing orange then back to white when reconnected
Chris-TalkTalk
Message 30 of 31
Hi SoF00,
Sorry to hear that you're experiencing problems with your service. Have you noticed if the light changes on your router when the connection drops?
