Capped at 60mbps
EdHodson
Message 11 of 11
Hi, something I have intended to ask about for ages...  I used to have faster download speed, but I appear to be capped at exactly 60mbps.  Can this be uncapped to provide my full sync speed please?Sync screenshotSync screenshot
10 REPLIES 10
Message 1 of 11
Hi Ed
That's great news, I'm so glad to hear this 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Message 2 of 11
Hi Debbie,
Sync speed is now 12mbps faster down, 4mbps faster up, and line seems clear of crackles.
Many thanks for your help!
Ed
Message 3 of 11
Hi @EdHodson
Openreach have now closed the fault as resolved.
Is everything working ok now?
Message 4 of 11
HI Ed
The fault has been assigned to a line engineer this morning, we should hopefully have further updates later this afternoon.
Message 5 of 11
Hi Ed
This fault is still under investigation with the Openreach line engineers and I will continue to monitor for additional updates.
Message 6 of 11
Hi Ed
I have escalated this fault over to Openreach to be investigated by a line engineer.
I will continue to monitor for additional updates and I will post back on this thread.
Thanks again.
Message 7 of 11
You won't get another reply before Monday from the support team. In the meantime, try connecting your router and phone directly at the test socket using a plugin microfilter (details here) and see if that helps with the noise on the line. If so, try switching off the router for a full 30 minutes to restart the session and see if that improves the sync. Let us know your findings. Either way, it may help if you leave things like that for the support team to test again.
Message 8 of 11
Hi Debbie,
Yes please:
>The line tests are detecting a potential fault with the landline service and this can affect the BB connection.
Oh, I wasn't aware of a fault.
>Do you use your landline for calls? Are you experiencing any noise on the line?
Yes we do and there has been some intermittent noise/crackle on the line for a couple of years.  Additonally, sometimes calls connect and the voice sounds like someone is talking into a tin foil baking tray and it is impossible to understand.  This is usually cleared by hanging up and redialling.
Thanks,
Ed
Message 9 of 11
Hi EdHodson
Do you still need help with this?
Message 10 of 11
Hi EdHodson
