Disable LAN DHCP
dw2020
Message 3 of 3
Hi There,
I have TT Fibre using the supplied router (version SG4K10002808t) and want to handle LAN DHCP using my Pi-Hole router instead but cannot see anywhere in the router interface to disabled LAN DHCP.  Am I missing something or can it not be done?
DW
Message 1 of 3
Perfect! Thank you!!
Message 2 of 3
Login to the router & go to:-
Dashboard > Manage my devices > Manage Advanced Settings > TalkTalk Wi-Fi hub > DHCP
Locate the "Enable" switch & set it to off.
