on 10-12-2023 09:21 PM
Good evening, I think I have made a mistake with getting the new eero router. I am getting big problems not being able to get a number of my home devices to connect to the WiFi. I have tried to use the legacy mode and turning off 5ghz.. This is a nightmare. I have an old laptop 15 years plus that connected no problem. I think I need to go back to the old talktalk router. Will talktalk supply me with that?.. I also wish to make it clear that talktalk should highlight this when people are going to purchase the new eero router.. Very unhappy customer.
Many thanks
S.ashford
on 15-12-2023 10:37 PM
Hi Keith. I am not able to get it to connect to the route of our Wi-Fi. What I have been trying to achieve is to connect a mesh Wi-Fi extender and then connect a wired ethernet cable. But I am not even able to get the mesh Wi-Fi extender to connect to the erro. I never had any problems with my connections in my whole house before I changed to the erro router.
on 15-12-2023 10:33 PM
Will it connect to the Eero without the extender being used at all?
on 15-12-2023 10:31 PM
on 15-12-2023 10:24 PM
I would turn the extender off as a trial, because as I said that is not really the way to extend a mesh network, you should use a second Eero. Let's see what TalkTalk say on Monday.
on 15-12-2023 10:20 PM
on 15-12-2023 09:52 PM
No. I still cannot the two devices to connect that I originally spoke about, yes it looks like that. I am on the correct channels now for my Wi-Fi but I am still having problems connecting to the arrow router via my Wi-Fi
on 15-12-2023 11:55 AM
Hi Musicmadsash,
Can you please retest and let me know if it's now working
on 14-12-2023 11:47 AM
Apologies for the delay, it's still with our Product Team, I'll let you know as soon as I have an update
on 14-12-2023 11:38 AM
Please can I have an update on when my issues is going to get sorted..
on 13-12-2023 03:10 PM
Thanks, I've passed on these details to our Product Team, I'll let you know when I receive an update
on 13-12-2023 02:40 PM
All added Debbie..
on 13-12-2023 11:59 AM
You can put them in the private notes section - community profile
on 13-12-2023 11:45 AM
I cant fine ware I need to but my account number and fttp order..debbie
on 13-12-2023 10:00 AM
Hi Musicmadsash
Please can you add your FTTP order number and account number to your Community Profile, I can then take a look at this for you.
Thanks @KeithFrench
on 13-12-2023 09:55 AM
The problem is that the Eero is using channel 155 in the 5GHz band and very few devices are compatible with this channel. There have now been quite a number of Eero's doing this, it is a known bug, but there is a fix for it. I will pass this back to the TalkTalk staff on this forum so that they can arrange to get this sorted for you.
on 12-12-2023 10:37 PM
Hi Keith.
Screenshots attached.. my network is Oberon.
on 12-12-2023 03:21 PM
Ah sorry, in that case, I sent you the wrong one. I am dealing with quite a few cases today. I'll PM it to you now.
on 12-12-2023 03:19 PM
Thats what you have set me. All about wireshark.. what am I ment to be doing here..
on 12-12-2023 03:12 PM
I am confused, did I mention Wireshark (I use it a lot), it has all been about WiFi interference from what I can see, or are you trying to investigate something else?
on 12-12-2023 03:07 PM
Thanks for this Keith. So I just have to install wire shark and run it on my pc. Is that correct..
