Eero router won't connect to internet
Hello247
Message 56 of 56
Hi all, I had full fibre fitted on monday and given an eero router. None of our devices can connect to it. I'm desperate to get the internet back as my son has autism and need it for communication. Any ideas?
ABerry
55 REPLIES 55
Message 41 of 56
Its flashing red
ABerry
Message 42 of 56
Thanks, what colour is the light on the router?
Message 43 of 56
No I didn't at first but have since and now the LAN light is on
ABerry
Message 44 of 56
OK thanks, did you plug the Ethernet cable into the WAN port of the router (not one of the LAN ports)?
Message 45 of 56
All it says is divice version DG804W-2.T5
TALK TALK product
ABerry
Message 46 of 56
What make and model is your previous router?
Message 47 of 56
I've only got my previous router that the ethernet cable will fit into. Just tried that. Just has Pon and power light on now.
ABerry
Message 48 of 56
OK thanks. Could you try connecting a device directly to the ONT with and Ethernet cable, bypassing the eero, and check to see if you can then connect to the Internet
Message 49 of 56
Lan, pon and power
ABerry
Message 50 of 56
OK thanks. I can see that you are on an Openreach circuit, could you just tell me which lights are on, on the ONT?
Message 51 of 56
I have updated my profile contacts etc
ABerry
Message 52 of 56
Hi Hello247,
  • Name
  • Telephone number or account number
  • Alternative contact number
Message 53 of 56
I had the same problem on my CityFibre connection as this & the TalkTalk forum staff here sorted it out very quickly. If it turns out to be caused by something else, they will get it sorted.
Hello247
Message 54 of 56
Thank you 😊 Feel like no one is helping me to sort this.
ABerry
Message 55 of 56
If your full fibre is provided by CityFibre, then you might need a profile change. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
