Fault - OCE help please
davep
Insightful One
Message 4 of 4
I ran a line test on "My Connection".  it suggested a fault.  Got the message
"We’re working on your fault
Updated: 08:07 on 12/10/2023
You have an open case and we are working to fix it. Check back in a few days: if you don't see this screen the issue is fixed."
Not sure why i went through this as all working reasonably well apart from occasional crackle on phone.
If an OCE picks this up can you tell me what is happening please.
Thanks in advence.
3 REPLIES 3
Message 1 of 4
Message 2 of 4
I think I'd seen the message of a fault before but followed it up this time.  I won't in future.
Thanks @Chris-TalkTalk
Chris-TalkTalk
Message 3 of 4
Hi Dave,
Line test is passing and connection looks fine. It looks as though a fault ticket has automatically been opened but I can't see why. I would just ignore it if your connection is OK
