on 07-07-2024 12:32 PM
Can anyone help ?
I want to upgrade to Full Fibre 150 (On 64 Fibre at present) I want to keep my Landline number and realise it with be over air, is this possible with Talktalk fibre 150, will I need a different landline phones and will I have to pay for phone calls using my landline number ? Or is everything included in the cost of the Full Fibre packages
on 07-07-2024 08:38 PM
Thanks for your help ferguson will try and get a decent price off talktalk know I got more info, thanks again to the community always get good advice on hear
on 07-07-2024 08:13 PM
Any modern handset should work, that isn't really an issue. The question is whether a VoIP service is available to you. That is what you need to check and confirm when ordering. If it is, then your existing landline number will remain unchanged.
on 07-07-2024 06:53 PM
Hi, Gliwmaeden2 many thanks for your reply just wish TT operaters could explain it so simply and easily
When you say order it with the FTTP order are you talking about ordering a new landline phone as I thought my original one would be ok
07-07-2024 12:46 PM - edited 07-07-2024 12:46 PM
@Jimpy2, a traditional landline phone should work with the Full Fibre router, but it's essential to order it with the FTTP order.
You'll be charged at the same rate as ordinary phone calls via copper, so no change there - it doesn't work like Skype / WhatsApp etc. Boosts can be added to mitigate the expense.
