Fibre 65 - Disconnecting.
Amy991
Message 11 of 11
The issue started yesterday evening (Sun 29th) & is continuing today.  My router (FAST5364, software version SG4K100136) is losing sync every 5 mins or so then reconnecting.
I've tried:
Connecting it to the test socket
Turning it off for 20 mins.
New filter and cable
Factory reset using pin at the back.
At the time of writing this post the connection the router has remained in sync now for 13mins!
Just wondering if a staff member could run a line test? I have no spare router here to test with unfortunately.
Thanks in advance,
Amy.
10 REPLIES 10
Message 1 of 11
HI Amy
Ahh great, thanks again 🙂
If you do experience any further issues then please let us know.
Message 2 of 11
Debbie,
I've just checked the box again and there it was folded up in the corner with the returns label. 😁
I'll get it sent off today.
Thanks again much appreciated,
Amy.
Message 3 of 11
Hi Amy
That's great 🙂
The returns bag should be in the same parcel as the new router.
If you haven't received a returns bag then I can send another one.
Message 4 of 11
Hi Debbie,
It arrived around 30 mins ago thanks! I have swapped it over using the new power lead/cables/filter etc in the box. It synced up straight away and hasn't dropped the connection so far!
Only the router arrived, no returns bag. I take it the returns bag will arrive separately?
Thanks again for your help,
Amy.
Message 5 of 11
Hi Amy
Message 7 of 11
Thank you so much Debbie, really appreciate it. Will let you know how I get on.
Amy
Message 8 of 11
Hi Amy
The replacement router is on its way, please allow 48hrs for this to arrive.
Amy991
Message 9 of 11
Hi Michelle,
Thanks so much for the quick reply. Yes please, if you could send a replacement router for testing that would be great! Happy to return this router in returns bag.
Thanks again,
Amy.
Message 10 of 11
Good afternoon,
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault, however I can see that the connection look very unstable. Would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
