Fibre 65 Internet keep going off.
Max2021
Sightseer
Message 22 of 22
My internet keeps going off intermittently for a few months now,i wasn,t so bothered until i got cameras inside and outside the house i had a live chat on Saturday and they said to reset my router and monitor the situation it,s gone off the 24,25, and twice today i would like a new router sent out to see if thats the problem otherwise i will move to a new provider sry it,s so long.
21 REPLIES 21
Message 1 of 22
Hi @Max2021
How are you getting on?
Message 2 of 22
Hi Max2021
I'm sorry for the delay.
Can I just check, is the replacement router connected at the test socket?
Did you use the new cables and filter that arrived with the new router?
Message 3 of 22
Thank you.
Message 4 of 22
Staff will not be back on here before Monday, @Max2021.
Support can be reached by contacting Talktalk directly. Opening hours are listed near the foot of this page:
Message 5 of 22
Updated: 07:23 on 31/08/2024
You have an open case and we are working to fix it. Check back in a few days.
We’ve opened a case
We’ve opened a repair case to investigate any potential issue with your connection.
We’re looking into it and should have an update in the next 5 minutes.
Come back to this timeline to see all future updates on your case.
About your case
Description
This case is open
Status
In-progress
Date reported
31/08/2024
Reference number
REP-14696168
obviously there is still a problem is someone going to fix this issue.
Message 6 of 22
I have set the router up and it has lost it,s connection again so it,s not the router could it be the switch on the wall,fed up of having to reconnect it.
Message 7 of 22
Hello again,
Ok, hopefully it will arrive today or tomorrow.
Message 8 of 22
No not yet.
Message 9 of 22
Hi Max,
Just checking back in to see if the replacement router has arrived?
Message 10 of 22
The replacement router is on the way and should arrive within the next 24-48hrs. Please let us know how you get on.
Max2021
Sightseer
Message 11 of 22
Yes please.
Message 12 of 22
My apologies, the FW is only for the Sagemcom router. Would you like us to send a Sagemcom wifi hub instead to see how the connection compares?
Max2021
Sightseer
Message 13 of 22
Hi yes it is huawei router.
Message 14 of 22
HI @Max2021
Can I just check, are you using the Huawei WIFI hub?
Max2021
Sightseer
Message 15 of 22
Yes please the connection goes off not just drops and i have to reconnect it manualy.
Message 16 of 22
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault. Can I just confirm, do any of the lights change on the ONT when your connection drops? We have a new version of firmware for the router, would you like to try this first to see how the connection compares?
Message 17 of 22
I am not asking you to put your private details on here, I am asking you to put them in your personal profile where only you and TalkTalk can see them.
Message 18 of 22
No i will live chat with them,not putting private details on here.
Message 19 of 22
OK, thanks for that. One more thing: make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that the support team can link your forum identity with your account and then wait for them to respond.
Message 20 of 22
Went through all the steps a few times,my router is an Huawei.
