on 10-09-2024 10:19 PM
This is causing 10% packet loss which is very noticeable when playing games. I take it the router is too weak to pass through the wall so can I upgrade to a third party router/modem combo?
My PC is currently unusable, we’ve been having problems for awhile but everytime I call they say there is nothing wrong with the line
on 17-09-2024 07:48 AM
on 11-09-2024 09:16 AM
Thanks Keith 🙂
on 11-09-2024 09:14 AM
That was also going to be my initial recommendation once I heard that you have the DG8041W. If you still need help after you have got the new router, let me know.
on 11-09-2024 07:11 AM
No problem 🙂
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send the replacement router.
on 11-09-2024 06:51 AM
Yes please that would be great.
on 11-09-2024 06:48 AM
Hi Knowlesknows
I think we should send a new router (Sagemcom) for testing. Would you like me to arrange this?
on 11-09-2024 06:00 AM
Morning Keith,
Device Version:DG8041W-2.TS
let me know what test data you need and I can do it when I’m home from work.
for reference I’m losing packets every 15-60 seconds ranging from 200-4000 ping.
on 10-09-2024 10:34 PM
What make/model of router are you using?
This could well be a WiFi interference issue, with which I can help a lot.
