Fibre 65 upgrade
rossi73
Message 34 of 34
Hi been a talk talk customer for years with zero issues. As my contact was coming to an end I decided to upgrade from fibre 35 to fibre 65. Since upgrading my internet speed and stability has been shocking bad. Struggling to hit 7 Mbps up and down, nothing like the 55 minimum guarantee speed. Can anyone have a look in to this please. Thanks.
33 REPLIES 33
rossi73
Message 21 of 34
Yes I've found the test socket. Just waiting for the router to do a 30 mins power down and I'll retry the test
Message 22 of 34
The 5C NTE socket should have a test socket. Does it look like the below?
Your guide to main phone sockets - TalkTalk Help & Support
rossi73
Message 23 of 34
Hi I have a 5c master socket and it hasn't got a test socket. As of this morning my speed has dropped again. Struggling to get 4 down and 7 up.
Edit, I've taken the face plate off the master socket and found the test port. Currently doing another 30 minutes power down.
Message 24 of 34
Does your main socket have a test socket please? If it does then could you try connecting the microfilter, router and phone at the test socket so we can see how the connection stats compare please?
rossi73
Message 25 of 34
Hi I'm used talktalks own speed check and speed test.net. just checked my new contract and it states minimum of 35 down and 13.8 up. Suppose it due to the line needing to settle.
Message 26 of 34
Are you using the TalkTalk speed test ?
Try some others also to give an average.
rossi73
Message 27 of 34
Hi done the 30 minutes power down. Speed looks like it's where it should be, 58 down but only 7 up? Sure I was quoted minimum of 13 up?
Message 28 of 34
No Problem 🙂
rossi73
Message 29 of 34
Hi trying the power down now.
Message 30 of 34
powering off for 30 minutes will allow a new session to start and should always be done when a speed increase is applied. Give it a try.
rossi73
Message 31 of 34
Hi. No I've not tried the 30 minutes power down. I spoke to someone in the tech department at talk talk and they advised that it takes 10 days for the line to settle after upgrading and they use DLM to monitor the line and adjust accordingly. Just have to wait by the looks of it.
Message 32 of 34
The router is in sync at 62.7mb.  Have you tried the 30 minute powerdown as advised ?
Divsec
Message 33 of 34
Hi @rossi73 have you tried a 30 minute reboot for your router? This often helps.
