Fibre 65 upgrade
rossi73
Message 34 of 34
Hi been a talk talk customer for years with zero issues. As my contact was coming to an end I decided to upgrade from fibre 35 to fibre 65. Since upgrading my internet speed and stability has been shocking bad. Struggling to hit 7 Mbps up and down, nothing like the 55 minimum guarantee speed. Can anyone have a look in to this please. Thanks.
33 REPLIES 33
Message 1 of 34
rossi73
Message 2 of 34
Hi so far it's been fine. Will keep testing this week and let you know if anything changes, but fingers crossed it looks like the problem was the router.
Anonymous User
Message 3 of 34
Thanks for the update. How has your connection been over the last 48hrs? Unfortunately we can't manually adjust the speed as DLM will provide the best balance between stability and speed for your connection. It's possible that you're seeing the best upload speeds for your line.
rossi73
Message 4 of 34
Hi router arrived and installed. Everything seams to be stable ATM. Download and upload seem to be at the correct levels. Upload was guaranteed at 13.8? Don't know if this is still and issue?
Message 5 of 34
A router is on the way to you, so this can be ruled out.
rossi73
Message 6 of 34
Still struggling to see how all this has happened. All my equipment is the same. All that's changed is upgrading to fiber 65, the issue must be at your end?
rossi73
Message 7 of 34
Hi what will the cost of this be? If it's free of charge then yes you can send a replacement router out.
Anonymous User
Message 8 of 34
Ok, would you like us to send a replacement router to rule this out?
rossi73
Message 9 of 34
No it's the same router that was sent out when we changed to fiber 35. I was told when I upgraded to fiber 65 that the router was compatible and wouldn't need changing.
Anonymous User
Message 10 of 34
Have we ever sent you a replacement router for testing purposes to rule this out?
rossi73
Message 11 of 34
Hi wired I'm getting 13 down and 7 up. Still nowhere near what I was guaranteed and nowhere near what I previously had.
Anonymous User
Message 12 of 34
I've re-checked the connection stats again and there is still no increase. What speeds are you seeing at the moment if you run a wired speed test please?
Anonymous User
Message 13 of 34
I'll post back again first thing in the morning after I've re-checked your connection stats again.
rossi73
Message 14 of 34
Hi thanks. Tested this morning and no change at my end.
Anonymous User
Message 15 of 34
I've re-checked the connection stats now and there has been no increase as yet so I'll re-check again tomorrow.
Message 16 of 34
Yes no problem
rossi73
Message 17 of 34
Ok thanks
Anonymous User
Message 18 of 34
It can take 24-48hrs for DLM to make changes to the speed so I'll re-check your stats again first thing in the morning.
rossi73
Message 19 of 34
 this is the results of the last test.
Anonymous User
Message 20 of 34
Thank you. Would it be possible to keep the router connected to the test socket until tomorrow and I will check your connection stats again?
Anonymous User
