on 26-04-2023 02:42 PM
Not sure for how long but its dropped from 56+ down to 24Mbs. Turned router off for 15 mins and back on but still the same.
Went through the talk talk speed test and then check line which said it found an issue and it said we need to contact you, there was a button to press to contact but it did nothing. I have the fault number but not sure if I should show it here.
fault info
