on 26-04-2023 02:42 PM
Not sure for how long but its dropped from 56+ down to 24Mbs. Turned router off for 15 mins and back on but still the same.
Went through the talk talk speed test and then check line which said it found an issue and it said we need to contact you, there was a button to press to contact but it did nothing. I have the fault number but not sure if I should show it here.
on 01-05-2023 12:01 PM
on 01-05-2023 11:49 AM
PM sent with details 🙂
on 01-05-2023 11:45 AM
Ok Via a PM for security I hope. 😙
on 01-05-2023 11:43 AM
OK, doing it now, will let you know the date in about 10 mins.
on 01-05-2023 11:37 AM
No day in mind, ASAP please
on 01-05-2023 11:34 AM
Thanks for confirming. Shall I book the earliest available or do you have any days in mind ?
on 01-05-2023 11:24 AM
Ok Done
on 01-05-2023 11:05 AM
just need to drop you a PM to confirm security details.
on 01-05-2023 11:02 AM
Yes please an engineer. I accept potential charges if the fault is found with my own rewiring etc etc. Although I do not have any extensions an so on.
on 01-05-2023 10:59 AM
Ok, in this case, the next option is to book an engineer. Would you like to arrange this now ?
on 01-05-2023 10:33 AM
Same, they don't move from this
My Internet Connection
Status
Connected
Current speeds
on 01-05-2023 08:36 AM
Hi Marvel
How are the speed results today ?
28-04-2023 05:23 PM - edited 28-04-2023 05:28 PM
Received the Router today and just fitted and there is no improvement in speed. Is another line test needed from your end. I will give it a day to see if it settles in any faster.
I keep checking the speed to the router and it does not seem to vary.
on 27-04-2023 11:05 AM
Hi Marvel
Thank you 🙂
on 27-04-2023 11:03 AM
Ok thank you. it seems to of got itself stuck at the below when it should be 56Mbs or more.
Current speeds
Download: 24.41 Mbps
Upload: 5.85 Mbps
Current Connection time
Online for 0:14:44 day(s)
I will report back when I have tested with the new router.
on 27-04-2023 07:17 AM
Hi Marvel
Let us know how the connection/speed compares with this router.
on 26-04-2023 04:26 PM
Yes please
on 26-04-2023 04:23 PM
Would you like me to send a router for testing before we proceed towards an engineer ?
26-04-2023 03:25 PM - edited 26-04-2023 03:59 PM
Do not have an alternative router to test. I have a NTE 5C MK 4 socket which was fitted a months ago when I had a disconnecting issue.
My landline is plugged into the front of this socket and so not hard wired to the base. I have pulled the landline out of the front of the socket and the speed is the same.
The router is and always was plugged directly into the front of the socket.
With the phone unplugged from the socket I do not have any of my own internal wiring other than that from the router to the socket with the supplied cable and then I have Cat 5 cables from the router to my equipment.
I have actually noticed a few outages over the last few days but put it down to the usual and dismissed it. You may be able to see them other than today when I have been turning it off and on again.
on 26-04-2023 02:54 PM
Line tests are showing an issue either close to or within the property.
Are you able to test with an alternative router at the 'Test Socket' directly ?
