Fibre router
paulchambers
Enlightened One
Message 23 of 23
Hi all . Having problems with the fibre router. Had no white light for quite a while. Now when i try to connect with any pc it returns DNS error  failed to connect . Switch it off works for 10 mins on and off then nothing again. Any ideas . Done all the normal checks.. Regards Paul
22 REPLIES 22
Chris-TalkTalk
Message 21 of 23
Hi Paul,
Your internet connection appears to be up and running at the moment, are you still experiencing problems?
Message 22 of 23
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
