Fluctuating Internet Speed
TimmyP
Message 9 of 9
I have had Fibre 35 for the past 2.5 years. Absolutely delighted with it. However, since Sunday the speed has been fluctuating wildly. I used to get a fixed maximum speed of around 33 Mbps, over the past 3 days, the maximum has been around 27, then dropping to 18, then dropping to 10. I keep performing a soft router reboot which seems to do a good job of getting the speed back to 27, for it to lose speed again. It's very frustrating. Any ideas?
Tim Pearson
8 REPLIES 8
Message 1 of 9
Hi TimmyP
I'm so glad to hear this 🙂
If you do experience any further issues then please let us know.
Message 2 of 9
Hi Debbie - thanks for the prompt. Yes, I have received the new router. I was going to leave it a few days before reporting back to you to allow time for me to fully monitor whether I was still experiencing speed fluctuations. However, I'm happy to report a positive outcome. After I had set up the new router and conducted a speed test, the speed instantly surged from 25-28 Mbps (old router) to 32-33 Mbps (new router) and so far (after 48 hours) no fluctuations in speed. So I think we can safely assume that the old router was failing. I will pack up the old router and send it back to you. Thank you for your continued help and support.
Tim Pearson
Message 3 of 9
Hi TimmyP
How are you getting on, have you received the replacement router?
Message 4 of 9
Hi TimmyP
Let us know how the connection/speed compares with this router.
TimmyP
Message 5 of 9
Thanks for getting it touch again, Michelle. Yes, do please send a replacement router - Huawei-DG8041W. Yes, fine for you to send me a replacement bag and I will return one back to you - no problem.
Tim Pearson
Message 6 of 9
Hi Timmy,
We sure can. We would also send a router returns bag so that one of the routers can be returned to us, would this be ok?
TimmyP
Message 7 of 9
Thank you for getting in touch, Michelle. I don't have any other devices connected wired. Alas, I don't have an alternative router which I could test, however, would it be possible for you to send me another router? My router is about 3 years old - maybe it's failing?
Tim Pearson
Message 8 of 9
Morning Timmy,
Sorry to hear this. I've run a few tests on your line now which are clear and the sync speed also look consistent. Can I just ask, do you have any devices connected wired? If so do they also fluctuate in speed? Do you have an alternative router that you could also test with please?
