on 29-12-2023 07:15 PM
New to fibre
Do I need a separate eero box, got a Grandstream digital voice box connected to my eero.
need a separate Ethernet connection to operate my Hive, can I bridge the connection or do I need separate eero box
on 02-01-2024 08:34 AM
Hi Pete,
I can see that you question has been answered, if you need any further assistance please let us know
on 29-12-2023 10:07 PM
That will do perfectly, I just don't like to be seen to advertise/recommend any 3rd party equipment.
on 29-12-2023 10:04 PM
I had the same problem get one of these boxes, run a cable from the Eero outlet to the box and then you have more outlets available. This is the one I bought from a well known on line store.
on 29-12-2023 09:59 PM
No, you don't need another Eero, just buy a cheap gigabit switch from somewhere.
