Red light flashing connected but not internet
Darcy41
Message 3 of 3
hi
standard talk talk router has red flashing light. No wifi connection to internet. Done power down, reset etc. still not working
thoughts?
thanks
Chris-TalkTalk
Message 1 of 3
Hi Darcy,
Sorry to hear that you're experiencing problems with your service. If you still need assistance can you please add your TalkTalk landline telephone number to your community profile
Message 2 of 3
Standard TalkTalk router means nothing. What make/model of router do you have (these details will be on a label on the rear or underside of it)?
