Hub 2 constantly blinking orange for 1 week
neerajmorar
Message 54 of 54
My Hub 2 has been constantly blinking orange for a week, I have no internet connection.
I have restarted my router numerous times and also reset it with a pin too.
I have reached out to TalkTalk support and they insist nothing is wrong with my connection.
It just constantly switches from slow blinking to fast blinking orange. The router SSID doesn’t appear in my wifi connection either.
53 REPLIES 53
Message 41 of 54
Thanks for confirming. You should be able to see the power light on the front of the router.
If this light is on, your router is receiving power.
Just to verify, is the router currently powered on?
Message 42 of 54
Yes that's correct
Message 43 of 54
Perfect! so if I go through the notes, the last time you spoke to us, we identified that you're using a WiFi Hub - FAST5464 router, can you please tell me if this is still correct?
Message 44 of 54
Yes we can all connect to emergency services still if needed
Message 45 of 54
Thank you very much. Openreach has a dedicated team to deal with vulnerable customers, and these are identified as Emergency Welfare Cases. An Emergency Welfare Case is where the customer has a life-threatening illness and applies to repair cases that have a total loss of service In-life or in a provisioned state that requires the urgent restoration of service.
Will you or anyone who lives with you be able to contact emergency services while your services remain impacted?
Message 46 of 54
No I do not, thanks
Message 47 of 54
Thanks for letting me know. Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Message 48 of 54
No difference, it's still switching between slow and fast blinking orange
Message 49 of 54
 I will need to this with you once more and try to get to the bottom of this issue. Could you please check your TalkTalk Internet access for me now and let me know if it works?
Message 50 of 54
This has been done, thanks
Message 51 of 54
Hi nambuso - that’s right, I’m messaging from home
nambuso-TT
Message 52 of 54
Hi there neerajmorar. I am very sorry to hear that you are having issues with your internet. I will run checks for you to determine the cause of the issue. Please confirm if you are messaging us from home, where the TalkTalk services are installed. Thanks
Message 53 of 54
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
