IP address is Amazon
Weevie
Insightful One
Message 5 of 5
Why does my TalkTalk IP address appear to be an Amazon one ?
This shows when using Speedtest and any IP checker...........
it shows ISP as Amazon
And my internet connection is like wading through sticky treacle - very "laggy" - although the actual connection speed is normal (65 + Mbps)
4 REPLIES 4
Message 1 of 5
When IP addresses or ranges are added it can take around 24hrs for those updates to propagate to all relevant servers to update the routing tables.
Weevie
Insightful One
Message 2 of 5
It looks as if it was a TT fault - Perhaps failing to rename the IP !!
The ISP was shown as Amazon rather than TT
I rebooted the router to reset the IP - Which is now correctly showing as TT
I have tried to post a screenshot but have not been able to.....
Weevie
Insightful One
Message 3 of 5
No - it looks more as if TT have used a load of redundant Amazon IP addresses and haven't reregistered them
Message 4 of 5
Many companies use Amazon web services (AWS), so it could be related to this.
