Intermittent connection
tobyisaacs
Message 24 of 24
I’ve had an intermittent connection for the past week or so, with drop outs ranging from a few minutes to several hours.
In the router logs I can see the error message ‘The WAN DHCP client process has failed on Vlan 36’.
I’ve spent several hours on chats with the support team, but haven’t had any luck.
What are the next step to getting this solved?
Thanks!
23 REPLIES 23
Message 21 of 24
Hi toby,
I'm sorry for the delay. I've run a test on the line which hasn't detected a fault, however the connection looks very unstable. Is the connection dropping on the Openreach modem or the router please? Has the set up changed at all since the engineer set this up? Have you added any additional equipment to the line?
tobyisaacs
Message 22 of 24
I’ve done that, thanks.
After factory resetting the router on the recommendation of the support chat, the connection is completely down now.
Message 23 of 24
Hi tobyisaacs
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
