on 26-11-2023 09:58 PM
Hi, we have fibre internet and it`s been fine but today we noticed the connection keeps dropping, we hadn`t noticed before because our phones go onto the mobile net.
Today ( sunday) our tablet and laptops had no connection.
The los light is off on the wall connector and the router light is normal ????? any ideas ?
Thanks,
Essex Bloke.......if it connects i will let you know.
on 29-11-2023 09:20 AM
That's great, thanks for letting me know 🙂
on 28-11-2023 06:35 PM
Thanks Chris, got it this afternoon, it worked as soon as i connected it, brilliant service from you all as always.
I have sent the old one back.
Thank you,
Essex Bloke
on 27-11-2023 02:05 PM
No problem, I'll order one now, it should be with you within a couple of days
on 27-11-2023 01:53 PM
Yes please, i haven`t got a spare any more.
Thank you for helping.
Essex Bloke
on 27-11-2023 01:50 PM
OK, maybe a problem with the router then, would you like me to send one to test with?
on 27-11-2023 01:44 PM
ahhhh, that works
on 27-11-2023 01:37 PM
OK thanks. Could you try connecting a device directly to the ONT with the Ethernet cable bypassing the router so that we can see if it's a problem with the router
on 27-11-2023 01:35 PM
Still no luck Chris,
Red light is still on router.
on 27-11-2023 01:17 PM
OK thanks. Could you unplug the Ethernet cable from the router and ONT and then plug it back in again and leave it for 5 minutes to see if the router connects
27-11-2023 09:54 AM - edited 27-11-2023 10:13 AM
Hi Chris ,
I switched off and I have just switched on and it's the same.
Ont, green lights
Router red, I rebooted that too.
on 27-11-2023 08:20 AM
Hi essexbloke,
Could you switch the ONT off for 30 minutes then switch back on and retest, if you still have no connection please let us know
on 27-11-2023 06:17 AM
this morning the router has a red light, tried rebooting it.
Socket is green lights.
on 26-11-2023 10:17 PM
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
