on 05-05-2025 09:59 AM
Our connection once again started disconnecting last night and has done so at least twice this morning as well. Both the download and upload connection speed have not gone above 0.8mbps since then. I've done all of the usual checks already and even turned the router off for around 30 minutes just to be sure.
on 05-06-2025 11:21 AM
I just need to confirm some personal information in order to continue with the engineer booking, please check your private messages.
on 05-06-2025 11:19 AM
Okay. Confirm away.
on 05-06-2025 11:18 AM
We've run a test on your line which has identified a line fault that requires a supplier escalation to resolve.
Typically these escalations involve an engineer conducting checks on the supplier network, though occasionally they may need to visit your premises. I’ll need to confirm some information with you before I go ahead and arrange the escalation.
on 05-06-2025 11:17 AM
Okay, thank you.
A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 6 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
on 05-06-2025 11:14 AM
No, it's never switched off.
on 05-06-2025 11:13 AM
Do you regularly turn your broadband router off? For example, do you switch your router off at night?
on 05-06-2025 11:12 AM
No but it does seem to happen more often when it's raining.
on 05-06-2025 11:06 AM
Do you find that your internet cuts out whenever you make or receive phone calls from your landline?
on 05-06-2025 11:03 AM
Yes. And when I check the router's internet settings page, it says "Disconnected".
on 05-06-2025 11:01 AM
So, is it safe to say the issue occurs everywhere?
on 05-06-2025 10:59 AM
Most of the devices in the house use ethernet cables and they are all affected too.
on 05-06-2025 10:56 AM
I understand, I need to establish if the problem is a general WiFi or Broadband issue, or if it's potentially a coverage issue. If the problem only occurs in places that may be further from the router, or are blocked by walls, doors or windows, then it's likely the issue is related to the Wi-Fi signal not being strong enough where you experience the problem.
-Issue occurs everywhere
-Issue only occurs in one or some locations
-Issue is not with Wi-Fi
-Issue is with a single device
on 05-06-2025 10:50 AM
It goes off at the router. Flashing orange disconnect light and everything.
on 05-06-2025 10:49 AM
Does the problem occur everywhere you try and use the WiFi, or just in certain parts of the house - for example upstairs, or outside the house?
on 05-06-2025 10:48 AM
No, we don't.
on 05-06-2025 10:45 AM
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
on 05-06-2025 10:37 AM
I am, yes.
on 05-06-2025 08:24 AM
I will run a diagnostics test on your line. Are you at home currently?
on 04-06-2025 05:20 PM
Both. It's going off for extended periods and when it comes back on, it's incredibly slow.
