on 10-09-2024 09:07 PM
Laptop was working fine, then recently it only locked into the 2.4Ghz network band. Rather than using 5Ghz.
Have tried everything mentioned in a previous post such as changing network preferences etc.
What was the fix for this?
on 11-09-2024 08:33 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 11-09-2024 08:29 AM
That is the problem then. Unless you have new high spec devices, they cannot work on such a high 5GHz channel.
There is a patch for this & I will ask TalkTalk to get it applied for you.
on 11-09-2024 07:41 AM
Eero 6.
2.4Ghz channel 6, control channel 6.
5Ghz channel 155, control channel 161.
on 10-09-2024 10:33 PM
I did see something briefly when you were using someone else's thread, please can you confirm the router that you are using & what 5GHz channel it is on?
