Hi my wifi hub black (DG8041W) has been down since yesterday
Choa69
Visitor
Message 10 of 10
Hi I noticed my WiFi hub Black always had issues with the router often not showing light only flashing Amber when I turn it on. Yet I had no connection issues when the router has no light. There was similar issues last month and I talked to talktalm staff who open cased but they were unable to solve the route or replace now the issue has happened. Please help me solve it. I have also try to solve it with my talktalk account and opened an case but I can't press the option to talk to chat with staff since the button doesn't work.
9 REPLIES 9
Message 1 of 10
Has the router arrived ?
Message 2 of 10
I've sent you a PM with the tracking info for your router dispatch.
Message 3 of 10
You're Welcome 🙂
Choa69
Visitor
Message 4 of 10
Thanks alot!
Message 5 of 10
Router ordered.  This should arrive in the next 24-48hrs.
Message 6 of 10
Yes please and make it quick as possible since in dire need of Internet connection.
Message 7 of 10
Would you like me to dispatch a replacement router for testing.
Choa69
Visitor
Message 8 of 10
The recent case I opened ref number is REP-14754817
Message 9 of 10
Would you like to try a replacement router ?
