Life. Is. Too. Short. FOR THIS
Maexesperated
Message 3 of 3
Trying to remove hp printer from iPad, TalkTalk, eero….so that I can reinstall it and maybe, maybe it will connect. And work.
Message 1 of 3
Hi @Maexesperated
As mentioned by @fr8ys I can help with this if you want.
Message 2 of 3
When installing the Eero, did you change the username and password to match the same as your old router? Doing this normally provides a seamless transition to the Eero.
Does you Epson require a WPS link to the router? If so then the Eero doesn't have that facility, but @KeithFrench has a workaround, but it does require another router.
Does your printer allow you to input username and password to the router? Has that not worked.
The Eero doesn't hold installation details and not sure what you mean by the TalkTalk reference either, but uninstalling an app from your iPad should follow the normal procedure for uninstalling apps, or am I misunderstanding something here. If so Google could be your friend.
You don't mention a PC which is normally the item that requires most installation. Is this not an issue?
Have you checked out a dedicated Epsom forum to see if others have had similar issues and found a solution?
Please let us know what you have tried so far so we may be able to offer more help
