on 13-01-2025 08:34 PM
Was having very slow speeds, ran the line test and it detected a fault on the line. The engineer came and supposedly fixed it but it's still exactly the same.
yesterday
Good morning,
I'm glad to hear this and thanks for letting us know 🙂
Sunday
Engineer paid a visit, everything working as it should.
Thank you.
Friday
No problem
Friday
Ok, thanks.
Friday
Thanks. Line test is still failing so I've raised this to Openreach as a non-appointed task. Openreach will investigate over the next few days and may contact you directly if they need to access your home
Thursday
You can run the test anytime.
Thursday
Ok, connected to the test socket now. Still getting the same slow speeds
which have dropped to 15Mbs down 10Mbs up.
Thursday
Hi @iustitia
Ok, thanks. As soon as the router is at the test socket then I will run the line tests.
Wednesday - last edited Thursday
Post back to let staff know when you have managed to set it up at the test socket.
They are on here early in the morning till mid afternoon, Monday to Friday, so they'll let you know the test result any time they have reached your thread if you can confirm you're set up with it at the test socket.
It doesn't take much time to actually run the tests, but let them know what time is NOT convenient - there'll be a little while of down time while they are testing, @iustitia, and you don't want that happening in the middle of you trying to get something important done.
Wednesday
Sorry not at home right now, will let you know when i can do it.
Wednesday
Hi @iustitia
Please can you connect the router at the test socket just whilst I run another line test? If the same fault is detected then I can pass this straight over to Openreach to be investigated by a line engineer.
Tuesday
It's worth checking whether your master socket has a test socket, @iustitia. The various types are explained here:
https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432
Staff will need to run tests with the router at the test socket to eliminate certain factors from the diagnosis of the problem.
Tuesday
HI,
no it isn't
Tuesday
Hi @iustitia
The line test is detecting a potential fault. Is the router currently connected at the test socket?
on 20-01-2025 07:53 PM
About 15Mbps up and about 20Mbps down.
on 20-01-2025 09:42 AM
Hi justitia,
What speeds are you getting when you run the speed test?
on 19-01-2025 01:50 PM
Please check back for a reply from staff after the weekend, @iustitia.
on 19-01-2025 11:30 AM
My speed is actually getting slower. Is it possible to get another
line test?
on 17-01-2025 07:00 PM
Yes for the full 30 min and i'm using a wired connection to my desktop.
on 17-01-2025 02:21 PM
Hi @iustitia
Just to confirm, was the router switched off for a full 30 minutes?
Are you able to run a wired speed test?
