on 13-01-2025 08:34 PM
Was having very slow speeds, ran the line test and it detected a fault on the line. The engineer came and supposedly fixed it but it's still exactly the same.
on 19-01-2025 11:30 AM
My speed is actually getting slower. Is it possible to get another
line test?
on 17-01-2025 07:00 PM
Yes for the full 30 min and i'm using a wired connection to my desktop.
on 17-01-2025 02:21 PM
Hi @iustitia
Just to confirm, was the router switched off for a full 30 minutes?
Are you able to run a wired speed test?
on 17-01-2025 02:19 PM
Tried this. My speed is still less than half.
on 14-01-2025 06:49 AM
Your line profile was set at 80mb yesterday, and the router is in sync now at 61mb.
Can you power off the router for 30 minutes to allow a new session to start, and then retest and see if your speeds improve.
