Lower download speeds than expected
cjedonline
Message 14 of 14
My package (Fibre 65) has a guaranteed download of 40mbps - for the last few weeks it's been down at 36/37mbps. Looking at the DSL stats from my router I see :
                                   Downstream                            Upstream
Actual Rate             39998 Kbps                               20000 Kbps
Attainable Rate      57449 Kbps                              20214 Kbps
SNR Margin            11 dB                                            6 dB
Attenuation            19 dB                                           27 dB
In the past I've had nearly 50mbps downloads. This looks suspiciously as though my connection is being limited to a maximum of 40mbps, rather than that being a minimum. Can anything be done from TalkTalk to fix this ?
13 REPLIES 13
Message 1 of 14
That's great news Charles, thanks for letting me know
Message 2 of 14
Right, it looks like the line was reset on the 31st of May, and now I have a much higher sync speed :
2024-05-31 17:40   Downstream               Upstream
Actual Rate            48999 Kbps                  20000 Kbps
Attainable Rate     60195 Kbps                   20500 Kbps
I did put the TalkTalk router in place from the 3rd to the 6th of June and it made no difference. I currently have :
2024-06-06 08:22    Downstream          Upstream
Actual Rate               48999 Kbps            19805 Kbps
Attainable Rate        58718 Kbps             19808 Kbps
So, it all looks good at the moment - looks like the line reset fixed the problem, at least for the moment.
  Charles.
Message 3 of 14
Message 4 of 14
OK Chris, I'll post back on Wednesday/Thursday next week after having the TalkTalk router connected for 48+ hours.
  Charles.
Message 5 of 14
Hi Charles,
I'm sorry, we can't fix DLM at a higher sync speed, it automatically adjusts the speed based on the number of disconnections and/or errors, in a given amount of time. If you could bump the thread when the TalkTalk router has been connected for 48 hours we can then check for any improvment
Message 6 of 14
Hi Chris,
    > DLM has set a line profile that is restricting your sync speed to 40Mbps
This was what I suspected. I could test with the TT router for 48 hours at the start of next week - it's not convenient to switch out my current router at the moment.
Is it possible to fix DLM at a higher sync speed (and avoid any downgrading as the line "trains" itself) ?
  Charles.
Message 7 of 14
OK thanks. DLM has set a line profile that is restricting your sync speed to 40Mbps. Could you test with the TalkTalk router connected, you would need to leave it there for at least 48 hours to see if DLM will move you to a faster profile
Message 8 of 14
Hi Chris, yes the landline and mobile numbers in my profile information are correct.
  Charles.
Message 9 of 14
Hi Charles,
Could you just check the telephone number in your community profile and confirm that it's your current TalkTalk landline telephone number
Message 10 of 14
Hi Michelle, the router is a DrayTek Vigor 2762 which I've had since July 2020. I use it instead of the TT supplied router as it supports additional features I need (and avoids switching router / network setup when I change providers).
  Charles.
Message 11 of 14
Hi Charles,
Ok thanks for confirming. How long have you had this current router for?
Message 12 of 14
Hi Michelle, no, there's no noise on the phone line (although we don't normally use it). There is a test socket in the Openreach box, but as we have no additional telephone extensions, I don't think connecting to it will make any difference.
   Charles.
Message 13 of 14
Good afternoon,
Thanks for your post. I've run a test on the line now which hasn't detected a fault. Is there any noise on the voice service? Does your main socket have a test socket please?
