New HUB2 Wi-Fi 5g not working
Antonisrho
Message 7 of 7
I was recently sent a new HUB2 router after going fibre to the premises. 5G does not work at all, I renamed it to have its own SSID but it won't show as an available network to connect to. By default (same 2.4g and 5G having the same SSID name) all devices would connect to the 2.4 network which is very glitchy and unstable: Devices get no internet even though they are connected and router is connected, suddenly no device would connect to the wi-fi at all etc. My router firmware is SG4K100174. Any solution/advice is more than welcome
6 REPLIES 6
Message 1 of 7
Hi Tony
That's great, I'm so glad to hear this 🙂
Happy New Year to you too 🙂
Antonisrho
Message 2 of 7
Morning Michelle, thanks for checking, yes so far so good, not sure why out of all the router restarts the last one was the only one that worked! Thanks again and have a happy new year!
Tony
Message 3 of 7
Just checking back in to see if everything is still ok?
Message 4 of 7
So long as it is working now.
Antonisrho
Message 5 of 7
Hi Keith,
Many thanks for the input, I had already set this to channel 36. Odd thing is once I changed the 5G SSID then band 1 (2.4) stopped working. I changed the name back to be the same for both bands, the wifi wouldn't activate at all and then reset the router. This seems to have fixed it and I can now see all the appropriate devices connected to 5G. I had restarted the touter countless of times but this time seems to have fixed it.
Cheers,
Tony
Message 6 of 7
Often V174 can start off using a 5GHz channel higher than most devices can support. Change it to channel 36 & see how that goes. To do this go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
