No internet connection
Ianhowes
Message 10 of 10
I currently have a white light on my router but no internet connection.  I restart the router and connection is restored for a short period then drops again
I’ve done a reset on the router but this doesn’t resolve the issue
I.howes
9 REPLIES 9
Message 1 of 10
Hi @Ianhowes
This is the latest update on this fault.
Update 8:40PM  December 17th 2024 - Our team are in the process of applying a solution to all impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.
Message 2 of 10
Hi @Ianhowes
My colleague has advised that they will keep you updated on this fault.
Message 3 of 10
Ok
I.howes
Message 4 of 10
Hi @Ianhowes
Thank you. I've asked the team to make contact with you ASAP. Please can you keep the router powered up without rebooting just whilst they complete their testing.
Message 5 of 10
Yes it is
I.howes
Message 6 of 10
Message 7 of 10
Hi Debbie
just home from work should I still try the instructions from your last message?
I.howes
Message 8 of 10
Hi @Ianhowes
Apologies for this.
Our engineers are investigating this issue and they have asked if you can try the below:
Change your router DNS settings to use Google DNS.
  • Open your web browser, type http://192.168.1.1 into the address bar and press Enter
  • Enter the username admin (in lowercase) and password (you'll find this on the removable settings card on the back of the Hub, and select OK
  • Select See internet settings
  • Select Manage advanced settings
  • Select TalkTalk WiFi Hub
  • Select DNS Tab
  • Make sure ON is enabled
  • Add Primary and Secondary DNS Servers ( Primary = 8.8.8.8  Secondary = 8.8.4.4 )
  • Select Apply
Please note ;  If you currently use any Homesafe services such as Homework Time etc.  This will not work whilst you have the DNS set to Google.
Message 9 of 10
Hi @Ianhowes
Apologies for this.
I think this may be related to a current fault that our engineers are investigating - (white light on router but no connection) I'll post back here as soon as I receive an update from the team investigating this.
Anonymous User
