Old router
Jeheley
Message 4 of 4
I’m having problems with my internet cutting in and out
It’s  not a WiFi problem as it happens even if I’m next  to the router
I have tried all the speed tests and they come back ok when it’s working but then can drop off
Im thinking it my be the router as I have had it quite a while
thanks
3 REPLIES 3
Message 1 of 4
Is your router currently connected to your test socket? - Your guide to main phone sockets - TalkTalk Help & Support
Jeheley
Message 2 of 4
We don’t use a landline
Chris-TalkTalk
Message 3 of 4
Hi Jeheley
The connection does look unstable, are you experiencing any problems with your telephone service, any noise on the line?
