PRINTER CONNECTION
kevincaterham
Message 4 of 4
I have bought a new printer and it won't connect to my router. Printer is a Canon pixma TS3355 and router is as supplied by Talktalk some years ago. Do I need a new router? The router has IP address, network and password on label if this can be useful. WPS button has no effect.
3 REPLIES 3
Message 1 of 4
Thanks @KeithFrench
@kevincaterham
Please can you add your name and TalkTalk landline number to your Community Profile.
Message 2 of 4
I have this printer myself and had no problem connecting it via WPS to numerous WiFi Hubs. Which make/model of router do you have?
Message 3 of 4
Hi @kevincaterham
Which router do you have? (make and model)
Have you tried factory resetting the router using the pin hole reset for ten seconds?
