on 14-04-2023 01:16 PM
I have a Huweii 633 router and am getting below the guaranteed levels with Fibre 65.
Currently had a test done, and it came back as there is a problem, could someone please look into this for me?
on 14-04-2023 02:48 PM
You're Welcome 🙂
on 14-04-2023 02:46 PM
Thank you Karl, hopefully this will resolve the issues I am having with speed.
Enjoy your day.
on 14-04-2023 02:31 PM
A router has been ordered for you.
on 14-04-2023 02:21 PM
That would be great Karl, and much appreciated. Maybe then, I will get the speed as promised.
Kind regards
on 14-04-2023 02:03 PM
You have had that router for about 7 years, would you like to try a new router ?
on 14-04-2023 01:54 PM
Apparently there is a test running at the moment, and I received an email to say that it was 'all good'. I have tried all of the suggestions, ie, switching router off for 20 mins etc, and there is another message on the complaints page telling me that the problem is still being investigated.
Could it be an old router do you think?
on 14-04-2023 01:52 PM
Hi Karl,
Do you mean by using the cable to the router and my laptop? The router is in my hall, so that wouldn't be a solution for me at all.
on 14-04-2023 01:36 PM
Are your devices using WiFi, Have you tested with a device that is wired to the router ?
