Recommend a router
Deanosafc24
Whizz Kid
Message 3 of 3
can anyone recommend a router to use with my Talktalk Fibre 250 please?
DMHALL
Message 1 of 3
@Deanosafc24
Fibre 250 is a G.fast service I believe, so you should be able to use any router which can connects to the modem via a WAN port. What router do you have presently and why are looking for an alternative?
Message 2 of 3
The standard router for that package is the eero 6 or the eero Pro 6 I think, but if some of the other posts I have seen from you, I think you currently have the Sagemcom F5364.
I have asked one of TalkTalk's support to pick your thread up and clarify your options.
