Router WI Fi channel changes
Evobee61
Message 4 of 4
Hi my wi fi channel keeps changing randomly, I set it myself to for example channel 6 which seems stable and then the wi fi keeps dropping out and I check the channel has changed to 11 for example is there some setting I need to alter to stop this from happening? thanks.
3 REPLIES 3
Message 1 of 4
Hi @Evobee61
How's the connection been since the WIFI optimisation was switched off?
Message 2 of 4
Hi Evobee61
Apologies for this.
I've switched the WIFI optimisation off, please let us know how the connection compares.
Divsec
Message 3 of 4
Hi @Evobee61 it's not a setting you can change but the staff here can help by disabling optimisation which often, doesn't optimise at all😞.
Bear in mind this setting sometimes reverts following a firmware upgrade and possibly a  full router reset.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
