on 26-09-2025 06:14 AM
My router TalkTalk Wifi Hub FAST5364-T8 stopped working today. No wifi (no brodcast), no ethernet (PC does not detect a connection), The LED flashes at bootup and stays orange. A hard reset also had the same effect. No Wifi or ethernet.
Can you send a replacement router please?
on 26-09-2025 09:24 AM
on 26-09-2025 09:20 AM
Do you currently have an Ethernet cable connected to the WAN (red) port on the back of your WiFi Hub?
on 26-09-2025 09:18 AM
@Philile-TT No active monitoring needed.
on 26-09-2025 09:17 AM
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
on 26-09-2025 09:09 AM
@Philile-TT correct. No internet.
I using my phone data for this conversation.
on 26-09-2025 09:06 AM
You have no internet access at all, correct?
on 26-09-2025 09:05 AM
@Philile-TT yes. I am at home.
on 26-09-2025 09:04 AM
I just need to make sure that it is not the line that is affected. Are you currently at home where the TalkTalk services are installed?
26-09-2025 08:59 AM - edited 26-09-2025 09:04 AM
@Philile-TT yes.Wifi Hub FAST5364-T8. connected and switched on.
things done:
1. turned off for 20 minutes.
2. hard reset using button.
same result. the orange LED blinks for sometime and then goes solid.
No wifi or ethernet (no wifi SSID broadcast, PC does not detect Ethernet ports.)
Phone line working normally.
on 26-09-2025 08:57 AM
@kannank are you currently using the Wi-Fi hub router?
on 26-09-2025 08:52 AM
Hi there @kannank I will have a look at this.
26-09-2025 08:10 AM - edited 26-09-2025 08:11 AM
lol, no, not the splitter. Good bit of humour in the morning 🤣
I can not connect to the router itself no WIFI and Ethernet, only the orange LED. It was working until late last night.
on 26-09-2025 08:06 AM
Hi @kannank your post has been escalated, not the splitter again is it?
