Router
Lilyloo
Message 8 of 8
Would it be possible to get replacement router
current router keeps getting slow connections and going off altogether
lines been checked but no problems showing with them
M nugent
7 REPLIES 7
Message 1 of 8
Hi Lilyloo,
How are you getting on? Has the replacement router arrived?
Message 2 of 8
Hi Lilyloo
Thank you 🙂
The router is on its way, please allow 48hrs for this to arrive.
Thanks again.
Message 3 of 8
Added to profile could you please confirm when router will be sent
M nugent
Message 4 of 8
Hi @Lilyloo
Apologies, please can you only add this information to your Community Profile.
Lilyloo
Message 5 of 8
REMOVED ****
M nugent
Message 6 of 8
Hi Lilyloo
I can send you a replacement router, please can you add your name and TalkTalk landline number to your Community Profile.
Message 7 of 8
Slow speeds to the device is very often not a router fault at all. However, what do you mean by "going off altogether"? Which make/model of router do you have & when it goes off, what are the light(s) showing on the router at that time?
